Alpha Testing
Annaliese McDermond edited this page Feb 24, 2022
1 revision
- Zoom – changing the bandwidth of the Panadapter. Zoom out=greater frequency spread; Zoom in=narrower frequency spread.
- Slice-Zoom – combines a Panadapter Zoom In or Zoom Out with a slice being the center zoom point
- Pan – Changing the relative frequency of the Panadapter.
- Tuning Mode – These are defined modes of control behavior of the Panadapter as a slice is being tuned. They are user selectable from the Panadapter
- Focus – the slice that is being controlled by the tuning device (previously called the active slice).
- Positive Control – User must initiate an action to enable/disable a particular control
- FC – FlexControl
- HID – Human Interface Device – A mouse or FC
- CP – Control Panel
- Create Initial Panadapter with one Slice with program invocation
- Left click / Drag Panadapter
- Slice off screen indicator / double click to bring into focus
- ZOOM IN: Left click on horizontal frequency labels and drag to the right
- ZOOM OUT: Left click on horizontal frequency labels and drag to the left
- ZOOM IN with Slice Staying Centered: Left click on horizontal frequency labels under Slice and drag to the right
- ZOOM OUT with Slice Staying Centered: Left click on horizontal frequency labels under Slice and drag to the left
- Double click on Slice Off Screen Indicator to pan the Panadapter to slice location
- Slice Drag Tuning: Display finger icon in RX filter/Left click/Drag Slice
- Fine Slice Tuning: Place cursor in slice RX filter area and use scroll wheel to tune (tune step fixed @ 10 Hz)
- Tuning via Direct Keyboard Entry: Left click in Slice frequency display to highlight / enter frequency via keyboard to change frequency of the slice (example: 14 = 14 MHz , 14.3 = 14.200 MHz, 14200 = 14.200 MHz, 7245 = 7.245 MHz)
- Change Filter Bandwidth: Position mouse cursor on filter shirt edge until cursor changes, click and drag filter skirt edges to adjust (like pSDR)
- ''''''Slice CP->Speaker Icon (audio controls): Audio gain slider control
- **Slice CP->Slice Indicator:**clicking on the slice designator indicator will minimize the slice CP. Clicking on it again will make it reappear
Panadapter->ANT: RF Gain (preamp) works. (far left= -10dB, 1st detent=0dB, in-between detents=10dB, 2nd detent=20dB, far right=30dB)
