SmartSDR Messages
Annaliese McDermond edited this page Feb 24, 2022
1 revision
Message Num | Message Text | Meaning |+SmartSDR Messages and their meanings |
0x10000001 | Client connected from IP | Notification that another client has connected to the radio |
0x31000001 | Service mode enabled on remote device | A service connection or command has been entered on the radio. Must be reset with a power cycle |
0xF3000001 | The maximum number of connected clients has been reached | No additional client connections can be made. Close a client to add an additional one |
0xF3000002 | OPERATING TEMPERATURE EXCEEDED. REBOOT REQUIRED. | The radio is shutting down to prevent thermal damage |
0x31000005 | APPROACHING MAX TEMP. TAKE CORRECTIVE ACTION. | The radio is reaching maximum operational temperature. Reduce temperature to avoid automatic shutdown |
0xF3000004 | Radio internal temp sensor fault, return for service | Internal temperature sensors are not functioning; the radio requires service to prevent thermal damage in the event of an over temperature event |
0xF3000005 | Cannot connect to the same radio from the same PC | Only one connection is allowed to an external PC for each radio |
0x31000002 | Transmit slice has not been selected | Without a transmit slice selected, the radio does not have a frequency for the transmitter. Select a slice to be the transmitter |
0x31000003 | Interlock is preventing transmission | Interlock prevention mechanisms are denying transmit. The most likely cause is an external device that is not ready such as an ATU, Amplifier or coupler |
0xE2000058 | The PTT timeout timer has elapsed. Release PTT to reset. | Push-to-talk has been pressed longer than the timer setting. Release the PTT and transmit again if required |
0x31000008 | Default profile cannot be modified. | An attempt was made to change the internal, default profile. Create a unique profile and save. |
0x31000008 | Import Config failed. | An attempt to import a configuration from disk has failed. The file is likely corrupted or the wrong type. |
0xF3000003 | Excess Power Detected on Receiver (>+20 dBm), transmitter has been unkeyed and receiver disconnected to protect hardware. | Power into the receiver exceeds thresholds set for the current hardware type |
0x31000009 | ATU tune error. Max power set too low for ATU | Increase the tune power and retry automatic tuner |
0x3100000A | Cannot delete the 'Default' profile | Create a new profile instead of attempting to delete the default profile |
