TCPIP audio client
Adds a slice receiver to a client's audio stream
C[D]<seq_number>|audio client <id> slice <index> add
<id> = The Client ID which to add the slice stream
<index> = The slice index whose stream to add
Example:
C42|audio client 1234ABCD slice 0 add
See Response Format for details on the format of the response messages from the radio
Hex Response | Message | Debug Output / Meaning |
00000000 | OK Slice added to | |
5000000D | Invalid slice receiver () | |
50000024 | No Audio Client found for submitted Client ID () | |
5000002C | Incorrect number of parameters |
Responses
Response Example:
R42|0||OK OK Slice 0 added to 1234ABCD
Remove (delete) a slice receiver stream from a client
C[D]<seq_number>|audio client <id> slice <index> remove
<id> = The Client ID from which to remove the slice stream
<index> = The index of the slice to be removed
Example:
C43|audio client 1234ABCD slice 0 remove
00000000 | OK Successfully removed slice from | |
50000025 | slice not found for () | |
Responses
Response Example:
R43|0||OK Successfully removed slice 0 from 1234ABCD
Set the slice gain for a client
C[D]<seq_number>|audio client <id> slice <index> gain <val>
<id> = the Client ID to modify
<index> = the slice receiver stream to modify the gain. The receivers are numbered starting with zero (0)
<val> = the new gain value to use - number in the range [0.0, 1.0]
Example:
C44|audio client 1234ABCD slice 0 gain 0.7
00000000 | OK slice gain set to for | |
5000000D | Invalid slice receiver number | |
50000025 | slice not found in Audio Client () | |
50000026 | Gain value not within the required [0.0,1.0] range () | |
Responses
Response Example:
R44|0||OK slice 0 gain set to 0.7 for 1234ABCD
Mute or un-mute the slice for a client
C[D]<seq_number>|audio client <id> slice <index> mute <val>
<val> = 1 to mute, 0 to un-mute
Example:
C44|audio client 0 slice 0 mute 1
00000000 | OK slice muted or un-muted for | |
Responses
Response Example:
R44|0||OK slice 0 muted for 0
Set the slice audio balance (how much audio goes to each ear)
C[D]<seq_number>|audio client <id> slice <index> pan <val>
<id> = The Client ID to modify
<index> = The slice receiver stream to modify. Slice receivers are numbered starting at 0.
<val> = The value to set balance in the range [0.0, 1.0] where 0.0 is full left and 1.0 is full right.
Example:
C45|audio client 1234ABCD slice 0 pan 0.4
00000000 | OK slice pan set to for | |
50000025 | slice not found for | |
50000027 | Pan value not within required [0.0, 1.0] range | |
Responses
Response Example:
R45|0||OK slice 0 pan set to 0.4 for 1234ABCD
