TCPIP cwx
Queues up text in the CWX buffer to be sent out as dots and dashes.
C[D]<seq_number>|cwx send "<message>" <block>
<message> = the string to be sent (replace spaces with hex 0x7f)
<block> = (optional) a number to help sync the reply with the original string
Example:
C19|cwx send "CQ TEST" 42 (*spaces shown in message here would be replaced by 0x7f)
See Response Format for details on the format of the response messages from the radio
Hex Response | Message | starting radio index for message, block |
00000000 | OK | |
5000002C | Incorrect number of parameters |
Responses
Response Example:
R19|0|170,42|
Clear the current CWX buffer
C[D]<seq_number>|cwx clear
Example:
C19|cwx clear
00000000 | OK | |
Responses
Response Example:
R19|0|
Set the CWX hang time delay in ms
C[D]<seq_number>|cwx delay <ms>
<ms> = The amount of time to delay in ms
Example:
C19|cwx erase 3 170
Hex Response | Message | erased start index, erased stop index (inclusive) |
00000000 | OK | |
Responses
Response Example:
R19|0|
Set the speed of the CW keyer to a specific words-per-minute (WPM) value. If a value below 5 is sent, 5 will be used. If a value above 100 is sent, 100 will be used.
C[D]<seq_number>|cw wpm <speed>
<speed> = a number between 5-100 setting the speed in words-per-minute
Example:
C19|cw wpm 25
Hex Response | Message | Debug Output / Meaning |
00000000 | OK | |
Responses
Response Example:
R19|0||
Erases characters from the CWX buffer
C[D]<seq_number>|cwx erase <num_chars> <index>
<num_chars> = The number of characters to erase
<index> = (optional) The index at which to begin erasing. If this is not provided, the end of the buffer is assumed.
Example:
C19|cwx erase 3 170
00000000 | OK | |
Responses
Response Example:
R19|0|170,172|
Inserts text into the CWX buffer at a specific index to be sent out as dots and dashes.
C[D]<seq_number>|cwx insert <index> "<message>" <block>
<index> = the index at which to insert the message
Example:
C19|cwx insert 170 "CQ " 43 (*spaces shown in the message here would be replaced by 0x7f)
Hex Response | Message | starting radio index for inserted message, block |
00000000 | OK | |
Responses
Response Example:
R19|0|170,43|
Save CWX macro buffers
C[D]<seq_number>|cwx macro save <macro#> "text message"
<macro#> = The number of the macro to be saved
Example:
C19|cwx save 1 "The quick brown fox jumps over a lazy dog"
00000000 | OK | |
5000002C | Incorrect number of parameters | |
5000007A | Incorrect macro number |
Responses
Response Example:
R19|0|1|
Send CWX macro buffers
C[D]<seq_number>|cwx macro send <macro#> [<block>]
<macro#> = The number of the macro to be sent
<block> = Optional. Can be set to send only certain bits of the message
Example:
C19|cwx send 1 [20,40]
00000000 | OK | |
Responses
Response Example:
R19|0|1|20,40|
Set flag that determines if QSK is allow in CWX
C[D]<seq_number>|cwx qsk_enabled 0|1
Example:
C19|cwx qsk_enabled 1
00000000 | OK | |
Responses
Response Example:
R19|0|
