TCPIP dax
Used for manipulation of DAX audio channels
C[D]<seq_number>|dax audio set <channel> [slice=<slice>] [tx=<1|0>]
<slice> = the slice number to assign a DAX channel to a slice
<1|0> = enable or disable the client as transmit source for DAX channel
Example:
C19|dax audio set 1 1 0
See Response Format for details on the format of the response messages from the radio
Hex Response | Message | Debug Output / Meaning |
00000000 | OK | |
5000000D | Invalid slice receiver | |
50000016 | Malformed Command | |
5000002C | Incorrect number of parameters | |
50000065 | Invalid DAX Channel |
Responses
Response Example:
R19|0|1|1|0|
Since multiple DAX clients can run on the same network using the same DAX channel, it is necessary to specify which one to use when transmitting. It uses the client ID for the sender of this command and sets this internally. So this command should be issued by the actual client that will supply transmit data samples (typically the DAX application).
Used for manipulation of DAX iq channels
C[D]<seq_number>|dax iq set <channel> [pan=<panadapter id>] [rate=<24|48|96|192>]
<channel> = DAX channel number
<panadapter id> = panadapter reference for the DAX channel
<rate> = sampling rate desired in ksps
Example:
C19|dax iq set 1 1 24
00000000 | OK | |
50000016 | Malformed command | |
5000002D | Bad field | |
50000066 | Invalid dax iq channel |
Responses
Response Example:
R19|0|1|1|24|
Used for manipulation of DAX TX channels
C[D]<seq_number>|dax tx <T|F|0|1>
Example:
C19|dax tx T
00000000 | OK | |
Responses
Response Example:
R19|0|1|
