TCPIP display pan
Create a panadapter display.
Only the GUI client may create a Panadapter successfully today. Issue #2323 has been added to address this bug.
C[D]<seq_number>|display pan c freq=<frequency> [ant=[antenna]] [x=[width]] [y=[height]]
<frequency> = frequency in MHz, up to 15 significant digits
[antenna] = (optional) antenna port designator (ANT1, ANT2, RX_A, RX_B, XVTR)
[width] = (optional) the width of the display in pixels
[height] = (optional) the height of the display in pixels
Example:
C21|display pan c 10.0 1 800 400
See Response Format for details on the format of the response messages from the radio
Hex Response | Message | Debug Output / Meaning |
00000000 | , | |
50000001 | Unable to get foundation receiver assignment | |
50000003 | License check failed, cannot create slice receiver | |
50000005 | The number or type of parameters supplied is incorrect | |
50000016 | Malformed command (unable to parse the frequency, or similar field | |
5000002C | Incorrect number of parameters | |
5000002D | Bad field |
Responses
= the 32-bit hex ID number of the stream to be used as a reference in the client. Your client implementation should save this value so that it can be used in subsequent "set" commands.
= similar reference to the waterfall stream that is automatically created with the Pandapter object.
Response Example:
R21|0|0x40000000,0x42000000
Remove (delete) a panadapter display
C[D]<seq_number>|display pan r <stream_id>
<stream_id> = the panadapter stream ID returned in the prior create command
Example:
C19|display pan r 0x40000000
00000000 | Successfully deleted panadapter | |
534C9999 | The slice number provided is invalid |
Responses
Response Example:
R19|0||
Retrieve settings that govern the RF Gain control in the radio. Since the RF Gain is a function of hardware implementations, each radio may have different control settings. This command retrieves the details that will make implementation of a control surface possible.
C[D]<seq_number>|display pan rfgain_info <stream_id>
Example:
C21|display pan rfgain_info 0x40000000
00000000 | ,,[,]... | the response contains the details needed to implement a control |
Responses
: low setting for the control : high setting for the control : the increment between steps, or granularity of the control : the locations of one or more markers to be placed on the control if possible. Each will be separated from the next by a comma
Response Example:
R21|0|-10,30,10,0,20
In this case the control should have setting that go from -10 to 30 in steps of 10 (so -10, 0, 10, 20, 30) and there should be a market at 0 and 20 if possible.
Change parameters that affect the panadapter display or underlying hardware
C[D]<seq_number>|display pan s <stream_id> <param=value> [<param=value>...]
<param=value> = a parameter and new value to be changed (one or more of these)
Example:
C12|display pan s xpixels=1000 ypixels=500
Parameter | Meaning and Values |+Valid set parameters |
center | change center frequency in MHz of the panadapter display (14.100, for example) |
bandwidth | change bandwidth in MHz of the panadapter display (0.100, for example) |
xpixels | change the width of the panadapter display in pixels (1000, for example) |
ypixels | change the height of the panadapter display in pixels (500, for example) |
fps | change the desired number of frames of panadapter data per second to be received (15-30 frames per second is typical) |
min_dbm | change the minimum (y-pixel-min) of the display in dBm (-150.0, for example) |
max_dbm | change the maximum (y-pixel-max) of the display in dBm (0.0, for example) |
port | change the target port number for the data[^1] |
ant | change the antenna for this display. The valid list of antennas can be retrieved with the TCP/IP antenna list command |
rfgain | change the rfgain for the SCU. The valid range for this command must be found using the rfgain_info command.[^2] |
average | change the level of averaging displayed <0-100> |
band | set which band is being used for the panafall. If specifying a regular HF band, command takes the form of band= . If specifying a XVTR band, command takes the form of band=x |
reset_band | reset the band |
autocenter | auto center the panadapter <1|0> |
line_duration | set the waterfall line duration <1-100> |
daxiq_channel | set the associated DAX IQ Channel <1-4> |
00000000 | Successfully deleted slice receiver | |
5000000C | The frequency requested is out of range | |
5000000D | Invalid slice receiver number | |
5000001D | Insufficient resources to tune to that frequency (requires new minimixer, not available) | |
Responses
Response Example:
R12|0||
[^1]: Generally you should filter based on VITA-49 packet headers, not port. Some microcontroller implementations may require port filtering, though
[^2]: Preamp and attenuator selection and settings are calculated automatically by SmartSDR based on this parameter
