TCPIP radio
Set the name of the radio which will show up in broadcasts and optionally the display.
C[D]<seq_number>|radio name <name>
< name > = alphanumeric name of the radio - if left blank, the current name is returned
Example:
C21|radio name 6M
See Response Format for details on the format of the response messages from the radio
Hex Response | Message | Debug Output / Meaning |
00000000 | <slice_rx> | OK radio name set |
5000002C | Radio name provided is too long (>15 characters) |
Responses
Response Example:
R21|0|OK
Set or retrieve the callsign of the radio which will show up in broadcasts and optionally the display.
C[D]<seq_number>|radio callsign <callsign>
< callsign > = alphanumeric callsign of the radio - if left blank, radio will return current callsign
Example:
C21|radio callsign K5FRS
00000000 | <slice_rx> | OK radio callsign set |
5000002C | Incorrect number of parameters |
Responses
Response Example:
R21|0|OK
Set the filter sharpness by mode. The filter sharpness adjusts the number of taps or stages in the filter which are traded off against latency.
C[D]<seq_number>|radio filter_sharpness <mode> <level=0-3> <auto_level=0|1|t|f>
< mode > = "voice", "cw" or "digital" - indicates which types of modes the sharpness applies to
< level > = a relative level of sharpness with 0 being least sharp and 3 most sharp.
With each level increase, latency doubles
< auto_level > = "0" or "1" turns off/on internal algorithm for automatic setting of the filter sharpness
Example:
C21|radio filter_sharpness voice level=2
00000000 | Filter settings successful | |
50000016 | malformed command / incorrect parameters | |
Responses
Response Example:
R21|0|OK
Restart (reboot) the radio. When this command is issued, the radio will drop any connections and will be unresponsive for approximately one minute while a reboot occurs.
C[D]<seq_number>|radio reboot
Example:
C1|radio reboot
No response to this command will be provided, typically.
Set various radio-wide parameters. See the table below for the details on each parameter, its effects and required parameters.
Parameter | Value |
leapseconds | Low resolution time-stamping uses NTP and the internal linux clock. To make adjustments for leap seconds, enter the number |
enforce_private_ip_connections | enable or disable <0|1> |
band_persistence_enabled | enable or disable <0|1> |
ntp_update | set rate in seconds |
tunepower | set the scale from 0-100 |
remote_on_enabled | enable or disable <0|1> |
full_duplex_enabled | enable or disable <0|1> |
daxiq_duplex_enabled | enable or disable <0|1> |
tnf_enabled | enable or disable <0|1> |
snap_tune_enabled | enable or disable <0|1> |
C[D]<seq_number>|radio set <command> <parameters>
<command >
< parameters > = see the individual set of commands to see the details
Example:
5000002D | Bad Field | |
50000033 | Parameters out of range |
Responses
Response Example:
R21|0|OK
C[D]<seq_number>|radio static_net_params ip=<num.num.num.num> gateway=<num.num.num.num> netmask=<num.num.num.num>
To reset to DHCP: send the command with `radio static_net_params reset`.
Note: Radio must be restarted following this command for the network changes to take effect.
Example:
C21|radio static_net_params ip=192.168.0.101 gateway=192.168.0.1 netmask=255.255.255.0
00000000 | OK | |
50000016 | Malformed Command | |
5000002C | Incorrect Number of Parameters |
Responses
Response Example:
R21|0|73737
Displays the amount of time the radio has been on sit boot-up
C[D]<seq_number>|radio uptime
Example:
C21|radio uptime
00000000 | OK | |
Responses
Response Example:
R21|0|73737
Configure the attached GPS module
C[D]<seq_number>|radio gps always|only|install|uninstall
Example:
C21|radio gps always
00000000 | <slice_rx> | OK |
Responses
Response Example:
R21|0||
Set the speed of the fan
C[D]<seq_number>|radio fan low|lowmid|mid|midhigh|high
Example:
C21|radio fan mid
50000016 | <slice_rx> | Malformed Command |
5000002C | Incorrect Parameters |
Responses
Response Example:
R21|0||
Set the intensity of the backlight on the front panel
C[D]<seq_number>|radio backlight [0-100]
Example:
C21|radio backlight 50
Responses
Response Example:
R21|0||
