TCPIP sub
This command will subscribe to messages produced by SmartSDR to inform a client of the status of certain objects. Once a subscription has been enabled, status messages will be sent to the client for changes in the object that is the target of the subscription. In the event that a subscription request is made for an object that does not exist, the following response will be generated:
Hex Response | Message | Debug Output / Meaning |
500000A3 | Invalid subscription object name |
Responses
To unsubscribe from an object, use the unsub command. This will revert the previous subscription command and discontinue status messages about the object.
Subscribe to status of any amplifiers that have registered with the radio over TCP/IP. (v1.10.8 and later)
C[D]<seq_number>|sub amplifier <handle|all>
<handle|all> = the 32-bit handle of the amplifier (if it is known) or all to subscribe to all amplifiers
Example:
C21|sub amplifier all
See Response Format for details on the format of the response messages from the radio
00000000 | OK subscription registered | |
5000002C | Incorrect number of parameters |
Responses
Response Example:
R21|0|
Subscribe to status of the internal antenna tuner (ATU) when present.
C[D]<seq_number>|sub atu all
Example:
C21|sub atu all
Responses
Response Example:
R21|0|
Subscribe to data from all or a specific audio stream.
C[D]<seq_number>|sub audio_stream <stream_id|all>
< stream_id |all> = the stream id to subscribe to or the word "all" to subscribe to all
Example:
C21|sub audio_stream all
Responses
Response Example:
R21|0|
Subscribe to changes to the CWX memories that are able to transmit specific CW phrases on command.
C[D]<seq_number>|sub cwx all
Example:
C21|sub cwx all
Responses
Response Example:
R21|0|
Subscribe to changes to a specific DAX audio channel or all DAX channels.
C[D]<seq_number>|sub dax <dax_channel|all>
<dax_channel|all> = the DAX audio channel to subscribe to or the word "all" to subscribe to all
Example:
C21|sub dax_channel all
Responses
Response Example:
R21|0|
Subscribe to changes to a specific DAX I/Q channel or all DAX I/Q channels.
C[D]<seq_number>|sub dax_iq <dax_iq_channel|all>
<dax_iq_channel|all> = the DAX I/Q channel to subscribe to or the word "all" to subscribe to all
Example:
C21|sub dax_iq_channel all
Responses
Response Example:
R21|0|
Subscribe to data from all or a specific foundation receiver. When any of the data that defines the foundation receiver changes, a status update will be sent to the client. This allows a client to keep track of objects in the radio. For example if a client is displaying panadapter 1 and another client moves the panadapter, the subscription will allow the second client to get an update on the new frequency.
C[D]<seq_number>|sub foundation <foundation_rx|all>
<foundation_rx|all> = the number of the foundation receiver to subscribe to or the word "all" to subscribe to all
Example:
C21|sub foundation all
Responses
Response Example:
R21|0|
Subscribe to data from the on-board GPS receiver (must be present). Data provided is from the GPS data strings that come from the engine and include latitude, longitude, grid square, altitude, satellites tracked and in-view, speed, frequency error, GPS status, track angle and the current time. This command will only function on FLEX-6000 that is GPS capable. On platforms that are not GPS capable (FLEX-6300, for example), the incorrect parameters response will be generated.
C[D]<seq_number>|sub gps all
Example:
C21|sub gps all
5000002C | Incorrect number of parameters or platform not capable of GPS operation |
Responses
Response Example:
R21|0|
Subscribe to changes, additions and deletions to the memory table.
C[D]<seq_number>|sub memories all
Example:
C19|sub memories all
00000000 | Successfully subscribed to the meter |
Responses
Response Example:
R19|0||
Subscribe to a specific meter. The list of meters must be obtained first by selecting the Meter List command and obtaining a list of meters.
C[D]<seq_number>|sub meter <meter_id>
<meter_id> = the identifier of the meter
Example:
C19|sub meter 1
Responses
Response Example:
R19|0||
Subscribe to data from all panadapters. When any of the data that defines any panadapter changes, a status update will be sent to the client.
C[D]<seq_number>|sub pan all>
Example:
C21|sub pan all
Responses
Response Example:
R21|0|
Subscribe to radio-wide data. Radio-wide data includes a number of types of information not bound to other objects including:
- file upload/download status
- client registrations/deregistrations
- interlock status (for transmitter state and ability to transmit)
- Tracking Notch Filters (TNF)
- Memories
- Profiles
- Radio status including:
* number of slices available
* filter sharpness state
* network parameters
* lineout gain
* remote on enable status
* PLL for adjustment of frequency standard
* radio nickname
* binaural status (radio-wide)
* full duplex status
* RTTY mark frequency default
* security including enforcement of private IP connections
- TURF (for region transmit frequency rules)
C[D]<seq_number>|sub radio all>
Example:
C21|sub radio all
Responses
Response Example:
R21|0|
Subscribe to data from all or a specific SCU. When any of the data that defines the SCU, a status update will be sent to the client. This allows a client to keep track of objects in the radio. For example if a client is displaying SCU 1 and another client enables the preamp, the subscription will allow the second client to get an update on the preamp status.
C[D]<seq_number>|sub scu <slice_rx|all>
<slice_rx|all> = the number of the scu to subscribe to or the word "all" to subscribe to all
Example:
C21|sub scu all
Responses
Response Example:
R21|0|
Subscribe to data from all or a specific slice receiver. When any of the data that defines the slice receiver changes, a status update will be sent to the client. This allows a client to keep track of objects in the radio. For example if a client is displaying slice receiver 1 and another client moves the receiver, the subscription will allow the second client to get an update on the new position of the slice receiver.
C[D]<seq_number>|sub slice <slice_rx|all>
<slice_rx|all> = the number of the slice receiver to subscribe to or the word "all" to subscribe to all
Example:
C21|sub slice all
Responses
Response Example:
R21|0|
Subscribe to data from the transmitter including power settings, speech processor status, mic levels, VOX status, transmit frequency and power, etc.
C[D]<seq_number>|sub tx all
Example:
C21|sub tx all
Responses
Response Example:
R21|0|
Subscribe to updates in the USB cable table or status of any of the current USB cables. (requires SmartSDR v1.10 or later)
C[D]<seq_number>|sub usb_cable all
Example:
C21|sub usb_cable all
Responses
Response Example:
R21|0|
Subscribe to data from the transverter objects.
C[D]<seq_number>|sub xvtr <unit|all>
<unit|all> = the unit number of the transverter object or the word "all" to subscribe to all
Example:
C21|sub xvtr all
Responses
Response Example:
R21|0|
