TCPIP transmit
Eric edited this page Dec 29, 2022
4 revisions
C[D]<seq_number>|transmit tune on|off
Example:
C19|transmit tune off
See Response Format for details on the format of the response messages from the radio
Hex Response | Message | Debug Output / Meaning |
00000000 | OK | |
5000002C | Incorrect number of parameters | |
5000003D | TX not supported | |
50000042 | Not ready to transmit | |
50000043 | No Transmitter |
Responses
Response Example:
R19|0|
Changes various operational parameters specific to transmission.
C[D]<seq_number>|transmit s <parameter=value> [<parameter=value>...]
Example:
C41|transmit s dax=1
Parameters that can be set and the appropriate values are listed in the table below:
Parameter | Value |
compander | enable/disable |
compander_level | range 0-100 |
dax | enable (dax=1) or disable (dax=0) DAX as the primary transmit audio source |
extra_mic_gain | range 0-24dB |
extra_line_gain | range 0-2dB |
hwalc_enabled | enable/disable |
max_power_level | range 0-100 |
met_in_rx | enable/disable |
miclevel | microphone level: range 0-100 |
mon_pan_cw | sidetone volume: range 0-100 |
mon_pan_sb | sidetone volume: range 0-100 |
mon_gain_cw | sidetone volume: range 0-100 |
mon_gain_sb | sidetone volume: range 0-100 |
mon | sidetone volume: range 0-100 |
rfpower | range 0-100 |
show_tx_in_waterfall | enable/disable |
speech_processor_enable | enable (speech_processor_enable=1) or disable (speech_processor_enable=0) speech processing |
speech_processor_level | speech processing level: 0=normal, 1=DX, 2=DX+ |
tunepower | tuning power level: range 0-100 |
vox | enable/disable |
vox_level | range 0-100 |
vox_delay | delay in ms |
00000000 | OK - update successful | |
50000016 | Malformed command | |
5000002D | Bad field | |
50000033 | Parameter out of range |
Responses
