TCPIP waveform
Annaliese McDermond edited this page Feb 25, 2022
3 revisions
C[D]<seq_number>|waveform create name=<name> mode=<mode>
<name> = name for the mode up to 20 characters in length
<mode> = 1-4 character mode designator
Example:
C19|waveform create testing test
See Response Format for details on the format of the response messages from the radio
Hex Response | Message | Debug Output / Meaning |
00000000 | OK | |
5000002C | Incorrect number of parameters |
Responses
Response Example:
R19|0|
This same commmand can be used for tx_filter
C[D]<seq_number>|waveform set rx_filter low_cut=<nnnn>|high_cut=<nnnn>|depth=<dddd>
<nnnn> = frequency in Hz
<dddd> = filter depth (128|256|512|1024|2048)
Example:
C19|ping
00000000 | OK | |
50000016 | Malformed Command | |
5000002C | Incorrect number of parameters | |
50000081 | Invalid Waveform |
Responses
Response Example:
R19|0|
C[D]<seq_number>|waveform set tx <0|1|T|F>
Example:
C19|waveform set tx 0
00000000 | OK | |
Responses
Response Example:
R19|0|
C[D]<seq_number>|waveform set udpport <port>
<port> = port number you would like set as UDP
Example:
C19|waveform set udpport 23
00000000 | OK | |
Responses
Response Example:
R19|0|
C[D]<seq_number>|waveform response <sequence>|<response>
<sequence> = sequence of originating command
<response> = response command sender
note that the vertical bar is part of the response, not an 'or'
Example:
C19|waveform response C18|50000016
00000000 | OK | |
Responses
Response Example:
R19|0|
