TCPIP xvtr
Annaliese McDermond edited this page Feb 25, 2022
4 revisions
Creates a new transverter record
C[D]<seq_number>|xvtr create
Example:
C19|xvtr create
See Response Format for details on the format of the response messages from the radio
Hex Response | Message | Debug Output / Meaning |
00000000 | align="left" | OK -- key to this transverter record is | |
5000002C | Incorrect number of parameters | |
5000007D | Failed to create transverter record |
Responses
Response Example:
R19|0|0000001|
Remove a transverter record
C[D]<seq_number>|xvtr remove <key>
Example:
C19|xvtr remove 00000001
00000000 | OK | |
5000007C | Transverter record not found |
Responses
Response Example:
R19|0
Sets a value in the transverter record created with a create command
C[D]<seq_number>|xvtr set <key> <parameter> <value>
Example:
C19|xvtr set 00000001 name 2304
Table of parameters that can be set:
Parameter | Value |
high_freq | high end of xvtr range (floating point number in MHz) |
name | name that appears in band selector |
low_freq | low end of xvtr range (floating point number in MHz) |
if_freq | intermediate frequency used by the radio (floating point number in MHz) |
if_offset_freq | error in the LO of the xvtr (floating point number in MHz) |
max_power | max percentage setting of transmit slider allowed for this xvtr (0-100) |
rx_gain | adjust the panadapter gain axis and slice meter accord to xvtr setting (floating point number in dB) |
rx_only | sets whether TX is allowed on this xvtr (state [see below]) |
two_meter_int | use internal 2m (state [see below]) |
See Boolean State for different text representations for a state See Response Format for details on the format of the response messages from the radio
00000000 | OK | |
5000002D | Bad field | |
Responses
Response Example:
R19|0
