SmartSDR Command Line API
Annaliese McDermond edited this page Feb 25, 2022
3 revisions
The SmartSDR command line API exists for local debugging of the hardware and/or the SmartSDR Engine software. Commands that are similar between the Command Line API and TCP/IP API use the same Engine functions to complete the commands.
- b → display banner
- cls → clear screen
- exit → terminate SmartSDR application
- help → request a list of commands
- ? → see help
- chain → control or display signal chain details
- client → control clients
- display → add/remove or control displays
- filt → adjust DSP filters in signal chains
- fdx → control foundation receivers
- fpga → read or write FPGA registers
- meter → control metering functions
- mmx → display status of mini-mixer receivers
- scu → control signal capture units
- sleep → sleep for one second
- slice → control slice receivers
- stream_stat → view status of in-bound streams (from FPGA)
- sub → add subscription to data updates
- sum → enable or disable summing
- trace → ?
- unsub → remove subscription to data updates
- version → report software version number
SmartSDR runs on multiple hardware platforms and the commands for these platforms varies. Here is a list of the commands that are used on the MICROBURST hardware platform:
- ad9122 → control or display DAC settings
- ad9467 → control or display ADC settings
- ad9512 → control or display master clock settings
- adau1761 → control or display CODEC settings
- adl5201 → control or display preamp/exciter settings
- alc → read ALC ADC
- date → display the current date
- eeprom → read or write the EEPROM
- fpga_raw_check → run an Ethernet check on data from FPGA to daVinci
- gpio → read or write GPIO lines on the daVinci
- i2c → execute raw I2C transfers
- init → write factory values to EEPROM
- io → read or write directly from or to daVinci memory
- log → adjust logging function
- m24c64 → read or write the TRX EEPROM
- psoc → control or display PSoC settings
- pa_relay → control relays on the PA board
- spi → execute raw SPI transfers
- time → display the current time
- trx_relay → control relays on the TRX board
